Today's release offers a variety of new capabilities for your Losant applications and solutions. This update provides a new integration, additional real-time dashboard blocks, and new nodes for both cloud and edge workflows.
Meridian Integration
Meridian, which is part of Aruba Networks, provides a suite of beacon-based indoor mapping and location services. Customers utilizing Meridian's Indoor Asset Tracking solution can now stream real-time location updates with the new Meridian integration.
The Meridian integration subscribes to Meridian's Websocket API endpoint, which receives all updates in real-time. You can then optionally filter this to include only Zone or Asset updates, and filter those updates to one or more individual map IDs.
If you're already a customer of Meridian, this provides a powerful way to use Losant for further application development on top of your location information. If you're a Losant customer and interested in an indoor positioning solution, please check out Meridian.
More Real-Time Dashboard Blocks
This release provides three additional real-time dashboard blocks: the Pie Chart, the Bar Chart, and the Indicator Block. Each of these blocks work on both historical and real-time data.
Historical mode allows you to view aggregated data over a time period, for example "the average temperature over the last 30 days". Real-time shows only the most up-to-date information as it's received by Losant.
Hash and Generate ID Workflow Nodes
This release provides two new nodes for both edge and cloud workflows: the Hash and Generate ID nodes.
The Hash Node makes it easy to hash data using a variety of common hashing algorithms like SHA256 or MD5. The Generate ID Node is a quick way to create unique IDs using standards like UUID or MongoDB's ObjectID specifications.
- Device attribute limit increased to 256.
- The Validate Payload Node schema can now come from a payload path or be a template.
- Application Globals can now be configured as "cloud only", which means their values will not be sent to Edge Compute devices.
- Changing dashboard context variables is now a much more seamless visual experience.
