Platform Update - Mini Dashboard Blocks and New Section Header Block
Brandon Cannaday
Today's platform update provides a way to show much more data on your Losant dashboards. We've also added a new section header block to label and separate various parts of larger dashboards.
With today's release, we've essentially doubled the number of cells in the underlying dashboard grid, which provides you with the ability to put twice as many blocks in the same space. We've also optimized every dashboard block to work at the smaller size.
On larger dashboards, it can sometimes be convenient to label specific sections. To accomplish this, we've added a new Section Header dashboard block.
A section header is placed and resized exactly like any other block. The section header also supports a description if your section requires additional explanation.
  • The debug panel now shows a stack trace if a Function Node throws an exception.
  • If there's a network or connectivity error, dashboard blocks will now display a small error icon on the bottom-left corner.
